Forced Induction - Truck manifold peepz q's within...
Pro Stock John
08-31-2006, 11:54 AM
Are most of you guys running Taylor heat sleeves?
danimal95
08-31-2006, 01:01 PM
i would assumje your asking for your own car????sleeves are not needed there is plenty of clearance around the plugs
ninetres
08-31-2006, 01:09 PM
I ordered some DEI from summit for $14 for 8 of them. Great insurance.
NA$TY-TA
08-31-2006, 01:15 PM
Im not running truck manifolds as you know John but its nice insurance just in case....
I like mine.... we burned a plug wire on my car...
Kyle
bboyferal
08-31-2006, 01:54 PM
I have them but I don't have truck mani's.
smokinHawk
08-31-2006, 02:12 PM
im not running a sleeve right now, seems to be doing ok. no signs of melting anywhere.
black_z
08-31-2006, 02:18 PM
Its cheap insurance. I would do it.
frcefed98
08-31-2006, 03:27 PM
I don't run em, and my wires are great. There is plenty of clearance, plus the stock heatshield that bolts to the manifolds works pretty good. Arent your truck manifolds coated as well?
J:D
Navy David SS
08-31-2006, 03:29 PM
Yep. Truck headers. My coil packs are re-located to under the dash, and without the sleeves they would be setting on the headers. Work great. No problems.
David
JRL96TA
08-31-2006, 04:00 PM
Make sure you check the heat ratings on the sleeve's. Usually the cheap ones are only rated to 500degrees.
Pro Stock John
08-31-2006, 05:10 PM
My hotsides all have black hi-temp coating. I don't believe in relocating the coils, I like them in the stock location. It's an awesome setup and one of my favorite aspects of the LSx series.
ninetres
08-31-2006, 06:10 PM
What kind of high temp coating is functional (like equal to wrapping them)?
black_z
08-31-2006, 06:27 PM
HOw well will powdercoat hold up on the truck manifolds for a turbo setup?
frcefed98
08-31-2006, 06:59 PM
Its not a powdercoating. Its thermal coating, BIG difference. I'm sure John went with a thermal retention coating on all hot side pipes.
The black thermal coating should be good up to 2k degrees.
J:D
ninetres
08-31-2006, 07:10 PM
J:D
IS it as effective as a header wrap? What if I use both :secret2:
Pro Stock John
08-31-2006, 10:25 PM
Black thermal coating yes.
smokinHawk
09-01-2006, 07:41 AM
on my silver ceramic coating i had on my tti kit it would reduce the surface temperature by 100*F (measured)
