6.0 or 5.3 heads on a 6.0
Im putting a 6.0 in my 01 Z28, it will have a TR224 cam and I have the choice of putting on 5.3 heads or the keeping the original 6.0 heads. No boost so I was wondering which head would be a better choice.
the 6.0 heads have intake runners like the LS6 which flow better than the 5.3's which are designed like the ls1's not sure what the CR difference is though. it will determine what head gaskets you use and if you mill them or not, but i would go with the 6.0 if it were me and mill and thinner gasket.
Truck addict
you will get a little better flow from the 6.0 heads but you will raise the compression ratio with the 5.3 heads. i think the 5.3 heads flow 190 cfm vs 210 on the 6.0 heads.
I finally found the specs on the 2 after a 20 minute or so google search. The 6.0 heads def outflow the 5.3 heads. They actually had better numbers than the LS6 heads. SO I will stick with the 6.0 heads and mill them .010 or so for a lil CR bump. Thanks for the replies guys.
Originally Posted by 68LS1WANNABE
What effect will milling have on the exhaust manifolds and valvetrain. It lowers the head on the engine so will there be issue's?
As for the exhaust, a few hundreds of an inch MAX should not throw off your exhaust manifolds enough to ever notice.
there are several guys on here selling 241 heads. cheap. found some brand new never ran heads for $150 plus shipping. you will have a higher compression ratio becuase of the smaller chamber and you wont loose an piston to valve clearance. id highly suggest using the cheap 241 heads that are rather undesirable on your motor rather than to spend money and mill your heads.
