LS7 clutch with resurfaced LS1 flywheels?
Old 08-31-2006, 06:53 PM
registered user
ScreaminRedZ's Avatar
Default LS7 clutch with resurfaced LS1 flywheels?
Just wondering if it's 100% necessary to get an LS2 flywheel to use this clutch on a 2002 fbody, or can a resurfaced stock LS1 flywheel be used? Will all of the stock hydraulics work with this setup?
Thanks!
Old 08-31-2006, 06:55 PM
Turo's Avatar
From what I have read on the COUNTLESS posts, no it will not work. You NEED an LS2 flywheel.
Old 08-31-2006, 06:56 PM
registered user
Is this due to the LS2 flywheel being thicker or thinner? If it's thicker, then could the LS1 flywheel be shimmed to work?
Thanks.
Old 08-31-2006, 06:58 PM
The PAT WS6's Avatar
jus save the all the trb and go with an ls2 flywheel
Old 08-31-2006, 07:11 PM
registered user
The flywheel it like $170. If I can get away with just shimming the LS1 flywheel then I'll do that. That's why I'm wondering with the actual reason is that you need the LS2.
Old 08-31-2006, 07:17 PM
warp10's Avatar
You NEED the LS2 flywheel. The contacts where the PP bolts on to the flywheel are raised and this is required. Look at mine in the picture and you will see the raised contact points.
Old 08-31-2006, 07:48 PM
Turo's Avatar
^^^What he said.
From my understanding, there is no way of getting the LS7 clutch to work with an LS1/6 flywheel.
Old 08-31-2006, 08:16 PM
gd1996's Avatar
Looks like a 2 step... so definetly need the correct one.
Old 08-31-2006, 08:47 PM
registered user
Thanks, that's all I wanted to know.
I just hate it when people have no problem telling you something, but have no idea why it has to be that way except because someone else told them it does.
Old 09-03-2006, 12:47 AM
gd1996's Avatar
FYI: If you get a used one and resurfaced, both parts need machined equally... but most machinists would know that.
Old 09-03-2006, 05:06 PM
01 BERGER CAMARO SS's Avatar
So Tru
Old 09-03-2006, 09:27 PM
LS1TECH Sponsor
badpewter-z's Avatar
yup ls2 is a STEPPED flywheel so the disc actully sinks into the flywhell unlike the flat ls1 flywheel .
Quick Reply: LS7 clutch with resurfaced LS1 flywheels?
