Ricky_GD
09-01-2006, 11:07 AM
How important is the fuel rail bleed valve cap? iv managed to loose mine:(
also will this valve leak at anypoint ( if the pressure is too low/high?) im using an adjustable regulater and havent checked the pressure yet but the valve is opening as the pump builds up the pressure then closes. opens again when the pressure drops a little ( on start up)
anyideas??
regards
anyideas??
regards
