Sponsor Group Purchases - Strange 12 Bolt/Dana S60 Rearend Group Purchase
tbyrne
09-01-2006, 04:42 PM
(Note: This GP has ended but see our posts in this thread from 9/19 for details on how to get a great deal!!!).
Is your rearend about to take it's last trip down the track? If so, we can help you with a Strange 12 bolt or one of the new Dana S60 rears! We're running a group purchase that covers both of these.
12 Bolt -
http://www.tbyrnemotorsports.com/ls1/strange12boltinfo.jpg
Gear ratios available are 3.42, 3.73, 3.90 and 4.10. The 3.90s will be noisy so Strange doesn't promote this one. This rearend now comes standard with the Super Strength posi. Each one is shipped ready to be installed. You will just need to swap the brakes from your current rear. Shipping is freight collect for this product so you will need to take care of that with the driver when he delivers.
GP prices -
PRG210-PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars) $2219.99
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin) $2219.99
R5206 Upgrade to aluminum support cover $114.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars.. $229.99
Dana S60 -
http://www.tbyrnemotorsports.com/ls1/danas60.jpg
Dana S60 features -
35 spline axles
HD Posi
Chrome Cover
3 or 4 channel ABS
You will need to send your brake backing plates in just before the rear is built so they can be built into the rear. We can sell a new set to you separate. The stock driveshaft will need to be shortened by 1.625".
The following gear ratios are available - 3.54, 3.73, 4.10, 4.30, 4.56, 4.88, 5.87.
The weight difference between Dana 60 and 12 bolt is 20-25 lbs, the Dana is heavier. Dana rear is fully assembled with posi weights around 215 lbs and 12 bolt is around 189 lbs (weight with brakes). The weight difference between 12 bolt and 9" is about 12-15 lbs the 12 bolt being lighter.
Ring gear sizes:
12 bolts ring gear only 8.875 OD
9 ring gear is is 9" OD
Dana has ring gear of 9.75 OD which is alot stronger than 12 bolt & 9".
The standard Dana gear (not Pro) can withstand close to 1200 RWHP.
The True-Track is posi is standard along with Power-Lock. These are good for about 600rwhp. The Dana's posi is alot stronger than a 12 bolt and the 9". This is because the Dana Posi's are 35 spline, 12 bolt is 33 spline and the 9" is a 33 spline.
GP prices -
PRSF05 Strange Dana S60 $2049.99
Driveshafts for Dana S60
U1699 Strange U1699 driveshaft 3"x.083" DOM chrome moly driveshaft with H.D. U-joints $209.99
U1700 Strange U1700 driveshaft 3"x.083" Seamless chrome moly driveshaft with High Imp. U-Joints $329.99
U1702 Strange U1702driveshaft 3"x.083" Seamless DOM chrome moly driveshaft with H.D. U-joints $289.99
5 or more orders are required by Tuesday, September 12th for this to go through. We will start ordering these when we have 5 orders in so it will be good to order early! This GP covers all rears that Strange produces so let us know if you need a rearend for a vehicle that isn't listed here.
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763.
Have a good day!
tbyrne
09-05-2006, 02:36 PM
2 orders in already!
Zitty'sZ
09-05-2006, 08:50 PM
I have a few questions
1) Will my UMI adjustable torque arm work with the 12 bolt and the s60?
2) The same thing for my UMI panhard bar?
3)Are both a direct bolt in or do I have to make them fit and will my stock driveshaft (STEEL) work with these?
4) How much will shipping cost to 33033?
5)How long does it take from order to delivery?
I am VERY interested in purchasing one of these! Thank you.
tbyrne
09-06-2006, 09:06 AM
The UMI parts should work with these. We haven't fit them with either of these rears to say for sure but the stock/aftermarket suspension components will usually bolt up. The stock driveshaft will need to be shortened by 1.625 to use it with the S60.
The rears are shipped freight collect so you would take care of that with the trucking company when they deliver. Shipping is usually in the $125. - $250. range. Delievery time will depend on how Strange is doing with production when everything is ordered. They should take at least 1-2 weeks to ship.
We now have 3 orders in.
Zitty'sZ
09-06-2006, 09:19 AM
I just called to order one of rears and the girl I spoke to said that you are NOT running a group purchase.What kind of circus are you guys running here?
tbyrne
09-06-2006, 12:05 PM
It's a three ring circus . Lions on one side, elephants in the center and those crazy monkeys riding motorcycles on the other side.
tbyrne
09-06-2006, 12:13 PM
Did you ask someone about a VaraRam group purchase this morning? Someone here asked me about that around 11 or so east coast time. I told her no. She let the person on the phone know about that. He told her that the GP was posted on September 1st. That is the same day this GP was posted. She confirmed with him that there is no Vararam GP
http://www.ls1tech.com/forums/attachment.php?attachmentid=74571&stc=1
Zitty'sZ
09-06-2006, 01:41 PM
No I asked about the strange rearend group purchase and she said no there was no group purchase and I repeated to her that on LS1 TECH.COM there is a thread dated 9-1-06 stating a group purchase on ALL strange rearends and she said no that is an old thread and the conversation ended! I have called your bussiness 3 times since that conversation trying to ask a few more questions BEFORE ordering a rear, but no one will return my calls and yes I have left my name and number TWICE! Now thats what I call customer service!! Have a nice day !!!
tbyrne
09-06-2006, 09:11 PM
I don't know... I heard what she was saying on the phone and I'm the one that told her that it was probably an old thread so I know which call it was. I was covering the call backs today and there were no calls that weren't returned as of 4:30. Unless for some reason your calls didn't make it onto the list but they are usually done right away.
tbyrne
09-07-2006, 07:17 PM
We're at 4 now. One more will put this over the top and get the first batch ordered!
mondi2002
09-07-2006, 09:15 PM
On the Dana 60, 3.54 is the highest gear ratio???
I have a Procharged 3.42 and feel like I could run out of gear.
tbyrne
09-08-2006, 09:11 AM
Yes, that is the highest they have for the S60.
This GP is now a go! :)
tbyrne
09-20-2006, 10:06 AM
Just a reminder, these prices will be good through 9/29.
98Z28CobraKiller
09-26-2006, 05:15 PM
Tbyrne, I have the $2049.00 for the S60 rear right know. My question is, can I order the rear right now (since there is a 2-3 week lead time) and have it in the que and then in a couple of weeks send in the cash for the backing plates and the shorter driveshaft? Also, do you guys sell a good torque arm that would work with my custom exhaust pictured below?
http://i26.photobucket.com/albums/c121/Bellos98/DSC01242.jpg
FCar2000TA
09-26-2006, 05:16 PM
If I can get my home equity line done, I'll be putting an order in.. might not make it though. :-(
tbyrne
09-26-2006, 08:22 PM
That won't be a problem. It looks like there is plenty of room for the stock or an aftermarket torque arm. We carry the Random Technology and BMR torque arms. Those should fit under there.
FCar2000TA: Let us know if you would like to get in on this.
Avengeance
09-27-2006, 10:51 AM
Question... are these S60s assembled by Tbyrne in house or are they a Strange assembled unit?
tbyrne
09-27-2006, 12:12 PM
They are assemblied at Strange.
98Z28CobraKiller
09-27-2006, 02:14 PM
My S60 is in the que. Wish me luck on getting one that doesn't whine.
FCar2000TA
09-27-2006, 02:37 PM
Can I get a price quote for the S60 shipped to 85234
35 spline
True-Trac
3chan ABS
tbyrne
09-28-2006, 08:27 AM
These rears are shipped freight collect so you'll need to take care of that with the trucking company when they deliver. The trucking co would call you a few days ahead of time to set up the delivery. Shipping is usually in the $125. - $250. range.
98Z28CobraKiller
09-28-2006, 10:55 AM
Mine was just under $2600.00 ( I want to say like $2598) w/ the backing plates and the middle priced drive shaft. It has the Tru trac w/ a 4.10 and the stock 2.5 studs on the axles. That should (read:better) be everything that I need in order to be able to bolt it in right out of the box. The freight is not included in that price. Carol and Holley were very helpfull and called me back several times to confirm some tech questions and stud options that I threw at them. If I get it within the 4 week delivery promised and it runs quiet, it will have been a completely pleasant buying experience.
FCar2000TA
09-29-2006, 09:33 AM
I just sent an e-mail from my work account. I definately want in on the GP, but won't have the ability to pay until early next week.
tbyrne
09-29-2006, 10:34 AM
No problem! We'll take care of you! :)
FCar2000TA
09-29-2006, 10:59 AM
No problem! We'll take care of you! :)What do I need to do to order the rear now, or do you want me to just wait until early next week when I have the card #
Avengeance
09-29-2006, 12:50 PM
Im in the same boat... I cannot submit the payment until next week. I just sold my beater to get this rear end :jest: and I still have to deposit the $ into my account, should take a few days to go through.
Tbyrne... can I still purchase the S60 next week for the GP price? Thank you!
tbyrne
09-29-2006, 01:32 PM
like there will be a wave of people ordering next week. We'll honor this for you guys next week.
FCar2000TA
09-29-2006, 02:01 PM
like there will be a wave of people ordering next week. We'll honor this for you guys next week.excellent!!!! Thanks Tom!!!!
FCar2000TA
09-29-2006, 04:22 PM
What are the differences in the driveshafts?
FCar2000TA
10-04-2006, 04:14 PM
Just got mine ordered!!!! Carol was very plesant to work with.
98Z28CobraKiller
10-05-2006, 09:05 AM
The driveshafts listed on the original post are all shorter than stock to work with the bigger than stock S60 rear. My best guess is that the more it costs, the stronger it is.
GMmexican
10-07-2006, 12:51 PM
let me know how the dana s60 hold up on you guys
W8N2SQZ
10-08-2006, 11:12 AM
Is it to late to try and get into this GP?
Glenn
FCar2000TA
10-09-2006, 10:22 AM
The driveshafts listed on the original post are all shorter than stock to work with the bigger than stock S60 rear. My best guess is that the more it costs, the stronger it is.That's what they said. The seamless one is straight pipe, with not seam (two pipes welded together). With no seam to be a possible weak point, the seamless is stronger.
Since I went S60 because it's the strongest... I decided to go seamless Driveshaft, cause it's the strongest.
Go big or go home, ya know.
98Z28CobraKiller
10-11-2006, 07:16 AM
I would like to know the difference between the U1700 and the U1702.
B.Buster
10-14-2006, 09:37 PM
Is it too late to get in ???
00 YEAH
10-22-2006, 04:47 PM
no kidding, looks like i might be in the market as well. planning on having another soon?
tbyrne
10-23-2006, 09:28 AM
There isn't to many more details for those shafts listed on the Strange site - http://www.strangeengineering.net/catalog/pdf/128.pdf#search='Strange%20Engineering%20driveshaft s'
This GP has ended but we have a store wide sale that wraps up on Thursday. Just give us a call to receive a quote.
98Z28CobraKiller
10-24-2006, 07:40 AM
Well, I found out the hard way that the shaft does not include the yoke. In order to reuse the stock w/ the 1 1/8 diameter hole, you will need Precision #447 adapter U-joint.
Black FormulaLs1
08-04-2007, 01:13 PM
so let me get this right:
The SD60 is the strongerst rear out there.
The SD60 only holds up to a 3:56 gear?
The SD60 requires a different yoke
and a different driveshaft?
98Z28CobraKiller
08-04-2007, 11:37 PM
Strongest due to the size of the ring gear but also heaviest.
3:56 or higher I believe
The pinion requires a 1350 U-joint. Therefore the weld-in yoke on the back of the drive shaft will either have to also accept the 1350 U-joint or you would need an adapter u-joint (not recommended). The slip yoke on the other end of the driveshaft must match the splines on the tranny output shaft. Drive shaft must be shortened or replaced with a shorter one.
Hope that clarifies for ya.
phrozen755
08-24-2007, 12:56 AM
but for the strange 12 bolt, what tbyrne is selling is a direct replacement no other needed items, correct? (96 LT1)
SuperSport4life
09-11-2007, 12:30 AM
Does Strange offer the 4.30 gear ratio for the 12 bolt? Does the GP include shipping? If not what would shipping be to zip code 11776?
tbyrne
09-12-2007, 08:29 AM
These are offered with up to a 4.10 gear. The GP ended awhile ago but we're currently offering $200.00 off the regular price of the rear. They are shipped freight collect so we don't receive shipping quotes for them. Last one that came to MA cost about $225. to ship.
http://www.tbyrne.com/Banners/banner1107a.gif (www.tbyrnemotorsports.com)
TBYRNE MOTORSPORTS LLC (http://www.tbyrnemotorsports.com)
ORDER LINE - 1-877-4-TBYRNE
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE (http://www.tbyrnemotorsports.com) FOR WEEKLY SPECIALS! INSTALLATION SPECIALS AVAILABLE!
slingshot928
09-18-2007, 01:08 PM
So the GP is over for the S60? I really was looking at one with a new driveshaft. If it is still going, can I pick up the rearend directly from strange? I live pretty close to Morton Grove. Can I also use my stock torque arm?
tbyrne
09-19-2007, 08:18 AM
The "GP" is over but that isn't required for a good deal now. We have an Everyday Low Price policy that will take care of you guys -
Some of you might have read the new announcement that is posted on our website. I'll provide a quick rundown of what we are doing with pricing now. Most products that we carry are being heavily discounted everyday so there is no need to wait for a sale or group purchase. Most of the prices listed on our website are at the lowest level that manufacturers allow us to advertise. You can receive a quote by giving us a call on our toll free line (1-877-482-9763 - In state # is - 1-508-636-0770.) or sending an e-mail to tbyrne@tbyrne.com. If you e-mail, please let us know what you are interested in and also include a phone number that we can contact you at. We will give you a call if we aren't allowed to provide the discounted price in writing.
90 same as cash financing is available to qualified buyers. You can apply on the Car Care ONE website (http://www.carcareone.net/CarCareOne/consumerapplytoday.htm).
Have a great day!
Tom
CHECK OUR WEBSITE (http://www.tbyrnemotorsports.com) FOR WEEKLY SPECIALS and PRICE MATCH PLUS POLICY! (http://www.tbyrnemotorsports.com/pricematch.htm)
tbyrne
09-19-2007, 10:08 AM
Forgot to mention that prices start at $1999.99 and there is no problem picking the rear up from Strange to save on shipping.
RooRnZ28
09-19-2007, 02:44 PM
the s60 doesnt have any lower gears than 3.56?
tbyrne
09-20-2007, 11:37 AM
The following gear ratios are available for the S60 - 3.54, 3.73, 4.10, 4.30, 4.56, 4.88, 5.87.
STROKED
10-01-2007, 08:20 PM
Can I get a quote also on a S60 shipped to 22712
With a detroit locker
with traction control
For a 98Z
Thanks steve
tbyrne
10-04-2007, 01:35 PM
You'll have to give us a call or e-mail tbyrne@tbyrne.com to receive a quote. The rears are shipped freight collect so we won't have shipping numbers for them. The trucking company would call a few days before delivery to set that up and provide the shipping amount.
Also, we are able to offer a slightly greater discount for orders that are placed by Friday, October 19th. These are probably the lowest price that we've had for these in years!
I'm going to leave this thread up for about a day then either delete it or have it locked so I can start a fresh one.
