Replacing clutch. Help.
Old 09-02-2006, 07:28 PM
BLUE01's Avatar
Default Replacing clutch. Help.
I am putting a centerforce DF clutch in my Camaro this weekend. I am using the stock flywheel and master. Replacing the slave. Do I need shims or anything else for this install. I don't think I do but want to make sure. Thanks
Old 09-02-2006, 11:02 PM
The PAT WS6's Avatar
if u resurface the flywheel yes i would use a shim
Old 09-03-2006, 01:12 AM
SPECIALIZED STAINLESS's Avatar
Where do you get shims from if they don't come with your clutch? And how do you know which to use? I'm putting in a Ram HD w/ a resurfaced flywheel. But I will also have an adjustable master cylinder...
Old 09-03-2006, 01:31 AM
Take 2's Avatar
Just be careful when you "Resurface" that you take to much off of it. I just went though that. I had the flywheel surfaced and it turned out so did the guy that had my car before me. Long story short I had to pull it all apart and change the Flywheel after I had just got it back together
Old 09-03-2006, 01:49 AM
damn that sucks!
call up centerforce and see if they can send u one if not a have a shim i could sell ya. pm me
Quick Reply: Replacing clutch. Help.
