Clutch Problem
Clutch Problem
After pulling my motor because of a spun bearing I put a fresh motor back in, fired it up, and no clutch engagement. I bled the slave and still not clutch. I have pedal pressure. Everything worked fine before I pulled the motor. I have a Spec 3, new master, slave, flywheel all with only 2500 or so miles. Any ideas on the culprit?
BTW The car sat for about 2 months while I was getting my new shortblock.
