Long tubes and Rear mount turbo
No felt gain for me. I actually felt better throttle response with the stock manifolds. Do a search but a lot of discussion has been made about heat loss due to the surface area of long tubes compared to stock manifolds as well as material of the two attributing to heat loss. I hated the ground clearance issues and love it so much better with the stock manifolds.
Loose power... do a search on this, we have had some very indepth conversations about this. Thermodynamics says <ding> more surface area increases heat dissipation reducing the overall effectiveness of the turbo.
(there are some exceptions to this... but it requires extencive coating or wrapping... again.. do a search on the subject)
I switched from LT back to stock manifolds. Throttle response was a little better. Spool time was also reduced. With the LT the wide band would jump about half a point up and down at idle and under normal driving. With the stock manifolds the wideband varies .1 up and down.
LOL! I’m actually in the process RIGHT NOW of removing my LG long tubes… For a minute there, I was getting second thoughts and decided to come in and do a search! Hahaha… OK, back to it!
Some time in the next week I’ll make a thread with side by side comparisons...
