sts cam selection
Old 09-03-2006, 08:36 PM
trans2000am's Avatar
Default sts cam selection
just bought a sts kit which cam should i go with?
Old 09-03-2006, 11:01 PM
trtturbo's Avatar
Not really a solid answer to this. Ls6, GT2-3, GT-7, reverse split with mid 220's, etc.. It really depends on a few things. Do you want the most efficient? Sacrafice a little for some lope? Pass emissions?
We have used what most would say is a bad cam for a turbo; 224/230 on a 112, but we like it. We have a car in the shop now that has a 226/220 .570.564 115. It too works great and has a smooth idle.
Almost anything will improve power in the end.
Old 09-03-2006, 11:45 PM
navymitch12's Avatar
i like my 224/224 .581/.581 114lsa
Old 09-03-2006, 11:50 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
i called comp and they suggested to me a 224/228 581.581 114, pretty similar. what is your set-up
Old 09-03-2006, 11:52 PM
sts....t67, FMIC.....8psi
its funny because i got the cam from my step dad back when i was still NA and still loved it...and it just so happened to work out great with the turbo kit as well
Old 09-04-2006, 07:33 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com/movies/sts3.mpg
http://www.exoticperformanceplus.com/movies/sts1.mpg
http://www.exoticperformanceplus.com/movies/sts5.mpg
http://www.exoticperformanceplus.com/movies/sts4.mpg
http://www.exoticperformanceplus.com...Car.php?car=32
Check out the above video clips and our STS project car. Bob
Old 09-04-2006, 09:55 AM
detroit_903's Avatar
About how much power-loss (typical range) are we talking about with a mean aggressive cam with the sts??
Old 09-04-2006, 10:13 AM
trtturbo's Avatar
I dont know if I call it mean and aggressive, but with a 224/230 .570's 112 cam, 402, stock 6.0 heads with good springs, Macs, TH-400, 12bolt, wrapped exhaust, T-70 it made 553 @ 7psi
Old 09-04-2006, 10:55 AM
bluecamaroz28's Avatar
How is 224/230 581.592 114 with STS on stock LS1 motor.
Old 09-04-2006, 11:01 AM
trtturbo's Avatar
IMO, it would work great. If you already have it, keep it. You could do alot worse.
Old 09-04-2006, 01:43 PM
67Firebird455's Avatar
The high lsa and overall less overlap is what makes a turbo cam a turbo cam. Avoiding reversion helps, period.
Old 09-04-2006, 02:15 PM
deadmanTA's Avatar
longrange4u had good results out of a small lingenfelter cam. Think it was the gt2-3
Old 09-04-2006, 02:22 PM
Restricted User
fenix99's Avatar
yea i think it was...and yea he did put down some verrrry nice numbers for a stock motor that is
Old 09-06-2006, 10:28 PM
dont have to pass emissions live in michigan just want something that sounds not stock but wont hurt the boost any answers, how about you bob cause i might be coming to you for tuning you just got doing my buddies 2002 camaro- f13 tune and his car is running great for all motor.
Old 09-06-2006, 10:48 PM
trtturbo's Avatar
It was a GT-7 and that cam may be for sale too.
Old 09-07-2006, 12:18 AM
longrange4u's Avatar
Yeap... comming out of the motor this weekend.
Old 09-08-2006, 04:40 PM
EPP
EPP's Avatar
Smile
http://www.exoticperformanceplus.com....html?item=679 Here is our cam that was used in this car. Bob
Old 09-08-2006, 05:45 PM
engineermike's Avatar
I have never seen a power reduction by adding duration and overlap into a cam in a turbo motor. Quite the opposite, actually.
Mike
Old 09-08-2006, 06:35 PM
Mike
If it's front mount on meth, or a good IC, then you wouldn't... But trying to spool a larger turbo out back without wrapping is a bitch. Have you seen a difference between cams when it comes to spooling the turbo on the same car?
Old 09-08-2006, 06:46 PM
I haven't seen a difference in spool time. However, obviously, a smaller cam will make more power down low in the off-boost condition, so it may seem to spool faster when it really isn't. Also, some say that the turbo GN stock cam was ground on a 106 LSA to provide some overlap, allowing raw fuel into the exhaust that would then burn and spool the turbo faster. Not sure if it's true or if it works, but I've heard those guys talk about it.
Mike
Quick Reply: sts cam selection
