93 t56 build up
Old 09-03-2006, 09:47 PM
ThirdgenRallySport's Avatar
Default 93 t56 build up
i know they are weaker but i do like the gear ratios. what are the weaknesses i have to upgrade to hold some power. I should be pushing 425hp and close to 500tq at the crank. So give me a list of stuff i need to up grade.
Old 09-04-2006, 05:30 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Input and output shafts. That is a lot of power out of a TBI 383 car. What else do you have done?
Old 09-04-2006, 03:19 PM
djz28's Avatar
Its a forged 383. 11:1 compression, fairly aggressive cam, dart iron eagle heads, holley stealth ram w/ twin 58mm TB, commander 950 ecm, long tubes to 3" true duals. MSD Dist, 8mm wires, desno plugs, crane Hi-6 box, walbro 255 fuel pump. had a build 700r4 w/ a 3200 stall but that tranny went out. so im gona try my luck w/ a 6 speed.
edit. this is travis(thirdgenrallysport) didnt feel like loggin out of my brothers name.
Old 09-04-2006, 04:44 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Sounds like a mean setup you got there! I would talk with Amber or Joe at T56rebuilds.com They should be able to point you in the right direction easily.
Old 09-04-2006, 11:16 PM
thanks
Quick Reply: 93 t56 build up
