Help!! Just Did LS6 Heads/Intake, Car backfires and has very slow throttle response..
Hey so like the topic says, we did an ls6 head and intake swap and its not right..... The driver side banks is a lot cooler than the passenger, and it almost seems like it's running lean, also backfiring and has a rough idle. Is this something a tune would normally do? Sounds like it's a plug/wire/coil issue not firing and causing it to run lean....
if stuff is not firing...its not lean ebcasue nothing is firing. Also, cold=not firing. The leaner an engine goes..the hotter it gets too. Who did the swap? sounds liek something get messed up. was the cam taken out? or set off of normal timing?
Originally Posted by csmc711
Uhm, yea, your welcome?? I wonder what happened to him? Huess it was a hit and run
Originally Posted by Talon WS6
Each coil pack has a 4 wire connector and 3 out of 4 wires are the same color the 2nd wire from the top is different on all 4 coils.
Cylinder #1 = Purple
Cylinder #3 = Lt Blue
Cylinder #5 = Dk Green
Cylinder #7 = Pink
Cylinder #2 = Pink
Cylinder #4 = Dk Green
Cylinder #6 = Lt Blue
Cylinder #8 = Purple
This is off of a 2000 TA but should still be the same layout
Check out this lay out to yours.
Cylinder #7 = Pink
Cylinder #2 = Pink
That is, ummm, strange there...
Isn't the firing order 1-8-7-2-6-5-4-3? That may be useful info.
Also sounds like it may have a small vacuum leak. My car did this after swapping intakes and it was a loose intake bolt. Just something pretty simple to rule out.
Good luck.
Good luck.
