Drag Racing Results - V6 wetkit shakedown runs
View Full Version : V6 wetkit shakedown runs
FloydSummerOf68
09-04-2006, 12:18 PM
First time out with my new kit.
55 wetshot
1.750 60
8.3 1/8 @ 81.5
13.13 1/4 @ 102
This is with a small cam, 4.10s and 3500 stall...not quite spraying out of the hole.
Will be going back to grab 12.99 on the 55 shot.
oner
09-04-2006, 05:32 PM
NICE!!!!! what do you run N/A? I always like to see the underestimated V6 firebird run great numbers. Congrats!!!
David@AZPS
09-04-2006, 05:40 PM
he was running 14.2 on the motor that night i believe..
FloydSummerOf68
09-04-2006, 06:08 PM
Thanks a lot.
Yeah, 14.2 that night, but I only made 2 passes n/a with a best 60 of 1.9 (usually grab 1.8s on motor)
Best on motor is a 13.9 at 2400da.
This winter I'm hoping 13.5 on motor with nothing added but good weather and a little weight reduction and 11s on a 150 shot.
Raceweight last night was 3420 and da was 1900ish
oner
09-04-2006, 06:42 PM
Thanks a lot.
:hail: damn 150 shot :eek2: make sure you get that on film!!!! Do you pull the tires of the ground when you launch? :hail:
oner
Thanks a lot.
:hail: damn 150 shot :eek2: make sure you get that on film!!!! Do you pull the tires off the ground when you launch? :hail:
FloydSummerOf68
09-04-2006, 06:57 PM
No, they dont pull on a 55 shot, but it definatley comes up a good deal in the front (skinnies, no swaybar, odyssey battery)
I'm getting my torque arm and adj phb on in the next week, so I'll be coming out of the hole a little harder to see what it can do and then up the shot to 75 to start knockin the 12s down a bit.
