any improvement on lighter vavles
hey guys im sending my 317 heads for my turbo build to get rebuilt and im already putting patriot dual gold springs kit along with a 5 angle job,but ferrea vavles is here in south florida so i was wondering if lighter stronger vavles will improve anything?
By taking weight away from your valvetrain and strengthing it at the sametime is benefical because it makes the valvetrain more stable at all RPM's i.e. reduced flexing, extending the life of the components. Lightning different components (retainers, locks, valves etc..) will reduce the amount of strain you put on the spring, allowing them to control the valves better. You will be able to bring the motor into higher RPM's if you need to because of the now stronger and lighter components.
