newby to ls1, need help
Old 09-04-2006, 08:46 PM
zaman406's Avatar
Default newby to ls1, need help
i have a lot of motor build exp,
i have a run a s/st 10.90 small block car
with a basic 406, glide
i just got this 2000 z28 with a auto
its got a 2.73 or a 3.08 gear im sure
and ran it at the track went
14.47 @ 99 with a 2.2 60 foot, and no spin
questions
what gears you guys been running and have good luck with
4.10 ? 3.73 ?
also i want to put a cam in , that wont stall when the air is
turned on, wich a lot of people i talked to seems to happen
and good cam, gear combo's out there, id like to get it into the 12's
@ 110 or so, so i need about 80 hp, and some luck
thanks frank
Old 09-04-2006, 09:36 PM
HeapaShifter's Avatar
3.73's seem to be the best for an automatic.
No cam should stall with a proper tune.
Old 09-04-2006, 09:50 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Match a cam and stall speed together. I would leave the rear end alone. Unless you are going to put in a 12 bolt. You are going to want a good tune to not have driveability issues or idle problems like was said before.
