LS1 to LS6 PCV conversion w/ LS1 steam tube.....GURU's please come inside!!
I was reading up on the LS1 to LS6 PCV conversions, and in my reading/searching I found that some instructions have a note stating you NEED to use the LS6 steam tubes (aka coolant lines) in order for the LS6 valley cover to fit.
I wanted to swap my LS6 steam tube out to the LS1 "X" style lines to improve the cooling in cylinder #7 and posibly #8, and upgrade the to the LS6 PCV system while incorperating a catch can.
Does anyone know why when doing the LS1 to LS6 PCV conversion, why the LS6 valley cover will not allow the LS1 steam tube to fit? Or has anyone done the LS1 steam tube inbetween the LS6 valley cover and LS6 intake manifold?
Apparently all you have to do to make the LS1 "X" style steam tube to fit under the LS6 intake manifold is to grind down some of the stiffening ribs on the bottom side of the intake. I'm assuming that the newer LS6 valley cover also impedes the lines some how. But I don't know......
Originally Posted by HeapaShifter
What you can do is get two of the 01-02 crossover tubes and put one on the front and the other on the rear. Works for me. I have the LS1 style valley cover with a LS6 intake.
So you have two of the front coolant pipes - (part #12568478)?
Don't you think the fluid flowing from the front to the back of the block with the LS1 "X" style collant pipe would be better?
Originally Posted by Ferocity02
I'm planning on using the LS6 valley cover with LS1 coolant lines and LS7 manifold, we'll see how it works out.
It'll be interesting to see how your project comes along. When are you attempting to put these parts together?
Originally Posted by 00Vette
That's what I have right now too. But I want to do the PCV upgrade.
Yes two front coolant pipe part #'s. I have a hose running from the back coolant pipe up to the front into a T-fitting so it also goes to the radiator. So it's still basically the X style setup.
Can you post up a picture or something? That sounds like a good idea.
I think the LS1 coolant line will work well under the LS7 intake manifold if you grind away the ribs underneath the manifold. But the LS6 valley cover is different than the LS1 valley cover and I don't think it will allow an LS1 coolant line to lay down like it needs too!
Unfortunately, I dont have the LS6 valley cover yet, so I can't mock it into place, but I thought the LS1 coolant lines would clear the LS6 valley cover, but not the LS6 intake manifold.
I'm just worried about the LS6 valley cover.
I drew a quick picture in Paint. Works the same as the X-style LS1 crossover.
Did you just run your own tubing?
Post up some pics when you get the time. I'd really like to see this.
Originally Posted by Cop Car
i never knew the LS6 valley cover was diffrent...
may i see a picture?
are you refering to the bottom of the intake or to the aluminum valley cover? i looked on how to and i only saw pics of an LS1 with its intake off. i know that LS6 intake bottoms are deeper and flatter than LS1s
Try this http://www.ls1howto.com/index.php?article=18
scroll down and you will see both ls1 and ls6 vally cover, easy to do
goo luck, Johnny
goo luck, Johnny
I test fitted the coolant tubes on, and the LS7 intake does not clear the tubes. It needs to drop down about 3/8" to seat right on the heads. The ribs on the bottom of the intake are not tall enough to grind, or else I will grind into the intake. I just ordered two front LS6 PVC tubes(12568478)and will do the T-fitting thing.
Here are pictures of the LS1 and LS6 valley covers. The LS6 has the the PCV valve end on it and the LS1 doesn't. Do you notice the little raised circles on the LS6 as oposed to the LS1 valley cover.
