Those racing with 650-700 rw what clutch are you using?
Old 09-05-2006, 02:28 PM
pushinfreight's Avatar
Default Those racing with 650-700 rw what clutch are you using?
Are you using a single or a twin setup? The search I did shows that those who are at this power level are using the twin disk setups. Has anyone used the ls2/ls7 combo and actually raced it on a regular basis? Track time means for me a minimum of twice a month at the track on mickeys or slicks. This will be going into a Fbody with full weight.
Old 09-05-2006, 08:25 PM
MIGHTYMOUSE's Avatar
i run a spec 5
Old 09-06-2006, 12:39 PM
Originally Posted by MIGHTYMOUSE
i run a spec 5
That is what is in it now but I keep chewing up fly wheels. Right now I can get it to move but I can be doing 65 on the highway, put it to the floor and the motor bounces off the rev limiter and I do not move any faster.
It worked for about 1500 miles and then things started going south. Once it comes apart I will be able to tell what has failed.
Old 09-06-2006, 01:16 PM
Daring Devil's Avatar
spec 5
working great so far
Old 09-11-2006, 06:32 PM
project nightmare's Avatar
its not shimmed right. these clutches needs to be shimmed , you can only get so much out of you master cyl.. the slave must be shimmed to help get the engagement spot right.. good luck..
Old 09-11-2006, 07:42 PM
1998z28ss's Avatar
Now this slave shim that you guys speak off does it come with a new clutch? My flywheel was ground so I'll be getting a .050 flywheel shim. There was a small steel ring that fell out when I took my slave out I guess this must be it? It was quite rusty. I'm hoping my new clutch will come with it. If not where do you get this?
Quick Reply: Those racing with 650-700 rw what clutch are you using?
