How to identify an LS6 intake?
Old 09-05-2006, 02:53 PM
Slow LT1's Avatar
Default How to identify an LS6 intake?
I have a '99 C5, and while troubleshooting the PCV system, I noticed the former owner installed a Z06 lifter valley cover. This makes me wonder if it has an LS6 intake as well. I know you can distinguish between an LS1 and an LS6 intake by looking on the ribbing on the bottom side of them, but if there any way to tell them apart with the intake still on the motor?
Sorry for the newb question but I couldn't find the answer in a search. Thanks.
Old 09-05-2006, 02:56 PM
B.W.'s Avatar
They look almost identical except for the bottom.
Old 09-05-2006, 03:04 PM
Slow LT1's Avatar
I guess I'll just pull the sucker off and find out, then. Thanks.
2001NBMZ28's Avatar
Look for the PN?
Old 09-05-2006, 03:09 PM
Slow LT1's Avatar
Originally Posted by 2001NBMZ28
Look for the PN?
Where's the PN located? I have a bunch of wires and hoses in the way
Old 09-05-2006, 03:11 PM
bjamick's Avatar
What is different about the bottom of an ls6 intake?? they are flat or someting??
Old 09-05-2006, 03:20 PM
B.W.'s Avatar
Yup, they are flat and the LS1 is not.
Actually, to the original poster check and see if the 2 coolant plugs on the front have a pipe going under the manifold to the rear. I am not sure if you will be able to see this on the vette. If they are not and just connected to eachother I'd say you have a LS6 manifold.
Old 09-05-2006, 03:27 PM
Shallow Bay's Avatar
http://www.ls1howto.com/howto/geniii...//IMAGE009.jpg
Old 09-05-2006, 03:30 PM
2001NBMZ28's Avatar
Yours might be in a different spot, but mine's stamped on the driver's side - between #3 and #5 - on top.
Old 09-05-2006, 03:49 PM
Slow LT1's Avatar
Looks like GM put the part number on the passanger side on Vettes. The part number is 12556333, which is in fact an LS1 intake. I'm kinda glad, b/c that means there's now more power to be had. Thanks for the quick responses.
Quick Reply: How to identify an LS6 intake?
