Everything's installed! Well, almost. TEA heads, MS4, soon to be FAST intake
Combo is as follows:
2002 Z06
TEA Stage 1.5 LS6 heads, milled ~0.030", stock headgasket
Flycut intake valve reliefs
TSP MS4 camshaft
TSP hardened pushrods
Vortex ram air box
TPIS 1 3/4" longtubes
Magnaflow off road X
Borla Stinger catback
Flow numbers are (on a 3.900" bore):
Here are the previous dyno numbers, cam only:
I'm hoping for some good numbers from this heads/cam package. Once I dyno I will install a FAST 90mm intake and an LS2 throttle body and redyno to see what changes it makes.
I tried to get some dyno time last saturday but all the local shops were closed due to the holiday weekend and the PINKS race at Ennis.
FWIW, with little tuning (just some VE manipulation to minimize ltrims with a speed density tuneup, then reenabling the MAF) I got 24 mpg on a trip to Austin last weekend...
2002 Z06
TSP MS4 camshaft
Vortex ram air box
Originally Posted by Hardtop
What cam were you using for your cam only numbers?
Bruce
Bruce
One thing that I CAN say, even though it's not scientific in the least, is that there is a HUGE difference in first gear behavior cam only vs. TEA heads/same cam.
Cam only, I could roll into the throttle in first gear from 2k rpm and the car would pull smoothly to redline (7100 rpm), tires never breaking traction.
With the TEA heads, I can roll into the throttle on the SAME street, similar weather, from 2k rpm and the car will accelerate smoothly up to 5-6k rpm, at which point the tires go up in smoke. It is
making THAT MUCH power. I don't want to make a guess as to how much more it's making, but it's a noticable difference. Again, the only change is the cylinder heads.
Originally Posted by anotherZfan
how was the flycutting?.....scale 1-10
Originally Posted by cws T/A
whats the no. 2 on the head flow sheet , stock ls6's .. or is that the exhuast ?
what intake cc , valves sizes, price ? sounds like a mean setup, do you daily drive this car?
