~Nitrous or Turbo~
~Nitrous or Turbo~
I was wondering which puts less strain on the internals of your motor and drivetrain? and a questions for those who have had both...which did you like better? leaving out the fact that you have to fill the bottle. Also when a mishap does happen and you blow your motor, which has the most damage?
Just for comparison:
8psi on the turbo
150 of nitrous
8psi on the turbo
150 of nitrous
It depends on boost and shot size...
Nitrous hits harder right away, but turbo makes more boost higher in the RPM as it spools so it hits hard.. but it hits gradually as RPM climb until it gets to the right boost.
They are both fairly safe if your use all proper safety measures.
Sorry i cant help much past that.
