Manual Fan Switch
Old 09-05-2006, 07:30 PM
BayAreaSS's Avatar
Default Manual Fan Switch
Ok i've been doing some searching but cant find the answer im looking for. If i was to run a manual fan switch with my stock T-stat would my car run any cooler? And can someone please tell me what i need to wire up my own switch because i dont want to buy the SLP one.
Thanks
Old 09-05-2006, 09:17 PM
THE CHOP SHOP's Avatar
Running the manual fan switch will help keep down temps when sitting in traffic or at the track. It will keep temps down but only when you want to lower them not all the time. If you wanted them to stay lower in general then a 160 thermostat will do that. There is debate about what thermostat should be run but the manual fan switch is a great addition to help keep the heat down during the summer.
Old 09-05-2006, 09:36 PM
BayAreaSS's Avatar
I really just want to keep the temps down in traffic, stop lights and after running the car hard. Thanks for the help
Old 09-06-2006, 02:52 PM
2001NBMZ28's Avatar
I'd just get the SLP switch, you can wire LEDs to it and can even see when low/high speed fans are on with the switch in the center (off) position - and will work with the car off so you don't leave it on accidently and run the battery down. Or just get your fan temps lowered.
Old 09-06-2006, 03:15 PM
Topless TA's Avatar
Try this link
Old 09-06-2006, 03:22 PM
nexvctm2001ss's Avatar
Temp. guages only work in 98 year models so it won't show that it is working on the guage but yes it should cool the motor down a bit more.
Old 09-06-2006, 03:30 PM
ZFan88's Avatar
try shbox.com. i got all the supplies for less than 20 bucks at radio shack and did the whole install in less than 2 hours. without any previous knowledge. works great
Old 09-06-2006, 04:38 PM
BayAreaSS's Avatar
Thanks for all the help guys
Old 09-06-2006, 06:13 PM
RrCoX22's Avatar
could always just get a tune to have it come on at certain temps
Old 09-06-2006, 06:18 PM
BayAreaSS's Avatar
I thought about that but i dont have the money right now. Im looking for a cheap alternative
