Need Help Th350 In My 98 Camaro???
all you need is a longer driveshaft and th350 tranny b&m sells a torque arm adapter to mount the torque arm in the original mounting location and it comes with a bracket for the transmission mount.If your car is a 98 model the flexplate has two type of bolt parterns one of them fit the th350 converter. Also contact TCI and purchase a pilot extension to use with a regular th350 converter if you don't want to use the pilot extension than you have to purchase a converter made to fit a th350 and have a longer hub to fit the ls1 pilot in the crank. I used the pilot extension on my car and it works great and i saved $300. I have the part# for the pilot extension but it's at my shop ill get it tomorrow and give it to you.
Not to jack the thread, but I am also about to do this swap as well. Car is still on the 10 bolt. What I need to know is .... how much longer does the driveshaft need to be? Also, what is needed to get the speedometer to work?
Thanks,
John
Thanks,
John
https://ls1tech.com/forums/automatic-transmission/479729-free-way-get-speedo-work-th350-th400.html for speedo, have to measure to know for the dive shaft. I'm doing this as well.
You can take your stock drive shaft to a shop and have it lengthened and balanced.
Or you can get a th350 with a longer tailshaft on it and it would actually bolt up to your stock driveshaft.
Location: Your girl's back door giving her the long stroke while you're at work
Originally Posted by ss1129
So a th350 with a 9" tailshaft will fit directly to an m6 driveshaft? What about the yoke, is it the same spline count/size?
