how high do u rev?
Old 09-06-2006, 12:25 PM
Mr David's Avatar
Default how high do u rev?
I'm curious what RPM some of you guys shift at. I have a Comp 224/224 and Comp beehive valve springs and hardened pushrods. I'm wondering how high I can take it and still be in the clear and making power. Right now I have the limiter set at 6600.
Old 09-06-2006, 12:42 PM
2blue's Avatar
I usually shift around 6200 RPM on a road course because I'm not really racing and trying to achieve maximum performance. You should check with Comp Cams, and they should tell you what the safe redline should be for your combination. Conventional wisdom here is that a good dual coil spring with a more agressive cam should be good for 7000 RPM. However, this is pretty close to the bottom end limit established by the connecting rod bolts. Several guys here have replaced the stock bolts with ARP's or Katech's?? so they can run up to 7K. Lastly, if you're drag racing, you need to be a little more conservative due to stresses on the clutch when launching. There's been a couple reported instances of clutches blowing apart and coming straight up through the dash. Fortunately, they went this way instead of taking off the drivers foot! A steel bellhousing or scatter shield may be more readilly available now. Good luck.
Old 09-06-2006, 12:43 PM
monicaz28's Avatar
Get it on a dyno and see where it peaks at... You won't need it much higher than that.
Old 09-06-2006, 12:47 PM
bjamick's Avatar
i shift bout 6200rpm or actually that is when my tranny shifts at but when i get my MS4 then ill do bout 6500 or 6600rpm
Old 09-06-2006, 01:04 PM
DONAIMIAN's Avatar
betwene 6500 and 6800 for me.
Old 09-06-2006, 01:06 PM
zspot98's Avatar
That's about the only true way to figure out what's best for your car IMO.
Old 09-06-2006, 01:16 PM
smokinHawk's Avatar
i try and shift at 7000rpm, i have a built bottom end with eagle rods, je pistons and arp rod bolts, and a 224/224-114 powered by a PTE88 turbo.
i picked up 7mph on the big end just by reving it out another 500rpm.
Old 09-06-2006, 01:22 PM
2000 Tran Zam's Avatar
i shift around 6900 rpms or so, it seems to like shifting there (at least in 3rd gear since its too violent in 1st or 2nd).
Old 09-06-2006, 03:07 PM
ArrestMeRed99Z28's Avatar
Just curious, what lobes is the cam ground on and what is the LSA? I am waiting to install a 224 on a 114 LSA on XE-R lobes and want to know where you plan on shifting so I can get an idea on mine
Old 09-06-2006, 07:47 PM
when i had my tr 224 on a 112 lsa cam i shifted at 6800 rpm..
Old 09-06-2006, 08:05 PM
hondakiller's Avatar
shifting at 6500, limiter at 6800, tr224 cam n/a. stock crank, forged rods and pistons as well but did the same on the stock shortblock.
Old 09-06-2006, 08:17 PM
Ryan02SS's Avatar
Shifting 6400rpms Rev limiter 6800 Setup peaks at 6050rpms and holds flat to 6400rpms. I lost MPH shifting at 6800rpms.
Old 09-06-2006, 08:25 PM
blacktransam's Avatar
when i peg the tack i wait a split second then shift.. but my cars a freak..
mike
Old 09-06-2006, 08:30 PM
BriancWS6's Avatar
With the new setup I have the lite set at 6600, limiter at 6800. When stock I had the lite set to 5900.
Old 09-06-2006, 08:33 PM
SHINER's Avatar
i have a 135K motor with 918s and torquer V2 and have my limiter set at 6300 becuase im kinda worried that the factory rod bolts wont hold.. You think i can set my rev limiter to 6400-6500 on my motor i dont have any shavings in my oil or anything.
Old 09-06-2006, 08:35 PM
SIC LSX's Avatar
6800 for me and i could go higher but nah!
Old 09-06-2006, 10:33 PM
SUTTERERMAN85's Avatar
6500 on a 140k now...
Old 09-06-2006, 10:37 PM
blkbird's Avatar
I dont go past 6200rpm which is where my car peaks at.....
Old 09-06-2006, 11:25 PM
Sigforty's Avatar
6800 to 7000 is where I shift, but I have a bigger cam. I am pushing the limits of the stock rod bolts there.
Old 09-06-2006, 11:35 PM
jermzz's Avatar
Quick Reply: how high do u rev?
