Fuel Rails ? What's needed
My engine is relativly stock no cam. I want to replace my fuel rails with red anodized. What all do I need to do the job complete. I need a complete parts list and the best source to get what I need. 1 stop shopping.
Aeromotive just released there complete bolt on fuel rail kit for 98-02 F-bodies. Comes with all the fittings, hose, rails, and the quick disconnect to convert the stock line to two -8AN Feeds. You also lucked out because the rails are red. It was a very easy install which only took me about an hour and a half. The part # for the kit was 14139. Hope this helps.
You can get the rail kit from any Aeromotive Distributor. It will be special order because it just came out. Your best bet will be to go through Summit Racing or Jeg's. Hope this helps.
