mikes98z
09-07-2006, 08:20 AM
I just threw a couple of codes on the 97 trans am and I am trying to figure it out so I am not spending a ton of money trying to fix it. I did a search here and it wasnt too much help.
First, threw a P0300 code - muti-cyl. misfire. The msd wires and coil are all new as well as the plugs. I checked them last night and I do not see any arcing or anything burnt. The engine runs perfect too so I do not get that one.
Second is P0400 code - EGR malfunction....found PVC valve hose whisling and collapsing so i changed it and put in a new valve. Could the EGR just be bad???? I have looked over all the hoses and I do not see any problems with them....its at the back of the intake so its going to a PITA to change if I have to. Anything else to look for? air pump?
Any input is appreciated.
Thanks!
Mike
Thanks!
Mike
