PUSH ROD LENGTH & IDLE
Old 09-07-2006, 01:24 PM
drkbluls1's Avatar
Default PUSH ROD LENGTH & IDLE
SO I got my car running with the new combo last night and I think I may have a push rod length issue. The heads are said to have been milled .020. the block was decked for straightness.... the car seems to not want to go anywhere over 4K. I realizse I have a stock tune still, HP tuners will be delivered today so that will change. any idea? also the car does not want to idle, any ideas there?
Old 09-08-2006, 10:39 AM
campbellshotrods's Avatar
Get me that f**king Camaro title and all your bad karma will go away.
https://ls1tech.com/forums/negative-trader-feedback/561907-avoid-drkbluls1.html
Old 09-08-2006, 07:08 PM
DaddySS's Avatar
Did you check for length? Base circle of cam, type of heads and gaskets, milling, will all affect the pushrod length required.
Old 09-08-2006, 11:14 PM
mr2guru's Avatar
https://ls1tech.com/forums/showthread.php?t=561907
