F14 vs. Torquer 2?...Whats the difference?
Old 09-07-2006, 01:47 PM
LS1IMPULSE's Avatar
Default F14 vs. Torquer 2?...Whats the difference?
I been looking for a new cam that is a decent size and still puts out some torque, doesnt need to kick in at 1500K RPM's or something i could only get with a very small cam but I want it decently low.
I found the Futural F14 (232"/234" .598"/.598" 112LSA) and really like what I have heard about it and then today i noticed the specs for the T2 cam (232/234 .595/.598 i would get 112) and they are basically the same cam? I realized the T2 is on XER lobes and the F14 in on some other not quite as aggresive lobes. TSP says the T2 will have a 1800-6400 powerband, while the F14 has a 3000-7000 powerband? what am I missing here for these to cam to have such different powerbands?
Old 09-07-2006, 01:52 PM
SUTTERERMAN85's Avatar
you couldnt tell the difference in the cams at all in the car.
Old 09-07-2006, 03:47 PM
LS1IMPULSE's Avatar
which should i got with? The T2 has XER lobes and I dont want sometihng to aggressive that will wear out my internals, but the F14 is supposed to have very un aggresive lobes?
Old 09-07-2006, 03:51 PM
sledneck687's Avatar
from what i have read the t2 has abotu the same powerband as the one from the f14 that you have listed. it seems to come in at about 3500 or so peaks about 6600 but will pull strong all the way till 7 if you want.
Old 09-07-2006, 03:55 PM
seth webster's Avatar
I got the T2 cam in my car with the PRC heads, i havent got it tuned or dynoed yet so i dont know what kind of power it makes but the cam turns up fast and it really starts to kick *** at 4000rpm+
Old 09-07-2006, 04:17 PM
2scoot's Avatar
T2 comes on very strong at 3200 in my ZO6. Great cam.
Old 09-07-2006, 04:34 PM
LS1IMPULSE's Avatar
are the XER lobes to agressive? how often will i have to replace my PRC golds?
Old 09-07-2006, 05:23 PM
Sigforty's Avatar
Here is my bolt on Z06 with the F14 cam dyno graph.
Then I added some Dart 205 heads and the car puts this down now.
If you have any questions about the F14 I can probably help as I daily drive my car.
Old 09-07-2006, 07:22 PM
GuitsBoy's Avatar
The powerbands are subjective. Companies pull those numbers directly out of their asses. Theyre useful for gauging different cams of the same manufacturer, but not necessarily across different vendors. I went from the f13 to the T2 and there wasnt very much difference. Probably wouldnt be able to tell any difference if someone switched them on your car in the middle of the night.
Old 09-08-2006, 12:19 AM
LS1IMPULSE's Avatar
If you can tell the difference would it be smarter to go with the F14 since the lobes are less agressive and will help internals last?
Old 09-08-2006, 03:50 AM
PREDATOR-Z's Avatar
What less agressive? Pfft
XE-R has a ramp variance rate of 49, and Cammotion is like 50/51
Hardly what i would call less aggressive!
The difference between the two will be at .200 and .400, but minute if you ask me.
Either or, they are both good cams, Look at the T2 results in my 370 cid (sig), mine is a 113+0
