vlave seal replacment on LS1
so what do i do? pull covers, rockers, springs and then i can get to the seals? Guess ill use compressed air to hold the valves up when taking the springs out
Best bet just buy all exhaust valve seals, that way no worries about mixing and matching.
Check out ls1howto.com. I just did this job last weekend and the pictures helped out. I used the Crane valve compressor and once I figured out that my springs were too wide for the machined reliefs (had to use the plate upside down) the job went smoothly.
I prefer to use the TDC method of holding up the valves. Also, when you press on the seals, make sure you feel them hit home. A lot of people dont press hard enough to fully seat them, and they wind up lifting and letting oil through. And yes, use all brown exhaust seals as its easier that way.
Bill
Cylinders 7 and 8 were a b&%ch to get the seals off due the limited amount of room.
r/
Frat
So y is it easier to use the exhaust seals only? and what exactly is the TDC method? does the compression hold the valves up when the piston is at TDC? and how would I know when each cylinder is at TDC after cylinder1? Thanks I really need to replace these seals
hey thanks for all the info man. About the TDC method thou, since its hitting the piston is there any chance of bending the valve since its pressing aginst the piston? What about denting it so its untrue and uneven with the valve seat?
Seriously, I think you are picturing this wrong. Here's what happens:
Move your piston to the top of it's travel (TDC) and then compress the spring and remove the locks. When the valve slips out of the spring compressor, it can only fall (via gravity, not get ejected) a fraction of an inch cause it will hit the piston. Just grab the stem with your fingers and move on.
