LS1-LS2 Keene Bell 2.6 2.8
Anyone putting a Keene Bell on a 402 I was wondering what kind of cam and type of pistions you would need if you already had a LS2 402 with 248/254 611/613 114 cam 2cc dished pistions about 10.9;1 compression. any info please write back thanks, George
A guy on corvetteforum.com did a KB on a 402. Check out the C5 forced induction forum, search for user AMERICAN HP. There's a few long threads that follow the build and results.
I've got that same motor. Was going to boost it this year but I'm waiting till next. I run 11.94:1 so my plan was to run some LQ9 truck heads with a mild clean up. I don't see any point in running super dollar heads on a boosted car. Unless of course you are trying to squeeze every ounce out of it an money is not an object. Change out the Texas Giant for a 224 and give her all the boost I can make. With the -2cc pistons you want to move into around a 74cc head. There are other variables, which you prolly know, but this is my plan on my motor. Individual results may vary
Originally Posted by Bandit28
what kind of #'s is he putting down
It's over 1000/1000 at the crank he said
He has 800lbs of torque @ 2k. Hp NEVER STOPS the incline... it's insane
OWN3D BY MY PROF!
will that lower compression
