4L60E & 4L80E Shifting
Old 09-08-2006, 04:31 PM
Y2K
Y2K's Avatar
Default 4L60E & 4L80E Shifting
hello there ...
can we let the 4L60E or 4L80E Shift manually …. By hand like the TH400 1,2,3, …? & how
Old 09-08-2006, 07:12 PM
dhdenney's Avatar
TransGo HD-3 shift kit is the only way I know how on the 80 but it would be forward pattern I think. I wish there was a RMVB for those things. Anyone know if anyone makes one???
On the 60, there is a stick shift option for all the TransGo kits I think. It will be forward pattern only too. You can get manual valve bodies for the 700r4 which is a non-electronic version of the 4l60e.
Old 09-09-2006, 02:14 AM
Y2K
Y2K's Avatar
Fine, right know I have 4L60 want to make it shift manually want should buy for it …?
Can you explain how I work for it to install the part I you have any solutions
Old 09-09-2006, 06:39 AM
dhdenney's Avatar
TCI makes manual valve bodies for the 700r4/4l60. Summit has them and probably Jeg's. Personally, I would leave the tranny guts to the pros.
Old 09-10-2006, 02:06 PM
Y2K
Y2K's Avatar
I’m one for international distributors for J.W. Performance Transmissions in UAE I never her about Manual Valve Bodies in 4L60 ,but I her form some guys that they do it ,work with TH-400 always
Even in Tci they don’t have for 4L60
I'll be glad to know who i do it in 4L60
Old 09-10-2006, 05:43 PM
dhdenney's Avatar
Here's some PNs for ya.
376010 TCI RMVB for 700r4
376015 TCI RMVB for 700r4 with full engine braking
Old 09-11-2006, 05:03 AM
Y2K
Y2K's Avatar
fine but i have to check it this kit fit in My 4L60E .. ? or 700r4 same us 4L60E ..?
Old 09-11-2006, 05:11 AM
JMBLOWNWS6's Avatar
Ill be shifting my 4l80 with the b&m by thursday Manual valve body installed
Old 09-11-2006, 06:24 AM
MrCadillac's Avatar
I thought trans go had a full manual kit for the 4l60?
I also thought trans go made a kit that left it auto style, but then if you wanted you could hold any gear to any rpm? Called the HD2?
Old 09-11-2006, 08:35 AM
dhdenney's Avatar
Far as I know these will only work in the 700r4.
Old 09-11-2006, 09:19 AM
Y2K
Y2K's Avatar
fine i see it in TRANS GO website i call them to day
thank mate
Old 09-11-2006, 09:20 AM
Y2K
Y2K's Avatar
thank you for replies i hust find TRANS GO KIT & fit in 4L60 E
Old 09-11-2006, 10:13 AM
MrCadillac's Avatar
I am the master. hahaha.... j/k, glad you found what you want.
Old 09-13-2006, 09:03 AM
Y2K
Y2K's Avatar
I have GMC Z71 v6 engine . I replace it with 8.1 I do ever think her even the ecu I tune it with HP tuners how ever the points her is the transmission that way i ask you mate about the shifting > know i have 2 solution & i need advies
1-Transmission Controll Unit (stand alone system )
2- trans go kit in part # 4L60E-HD2 i never try it
Old 09-13-2006, 09:35 PM
jason99frc's Avatar
As for the 4L80E; Compushift makes a stand alone controller that you can wire paddle shifters or what ever you want to use as a gear selector. I know its not the same as manually moving the stick but it can react just as fast.
Old 09-13-2006, 11:03 PM
dhdenney's Avatar
Found this the other day, a reverse manual valve body 4l80e w/ trans brake.
www.ckperformance.com/
Old 09-14-2006, 04:52 AM
Y2K
Y2K's Avatar
fine ,i order the manual valve body if in not work probloly i Use Transmission Controll Unit .
Quick Reply: 4L60E & 4L80E Shifting
