Injector Sizing W/ Nos
ANY EXPERTS PLS HELP..
CURRENT COMBO 408 CID W/ DIRECT PORT PLAN ON SPRAYING 400 SHOT..
SO .. INJECTOR SIZE FOR 550 RWHP N/A = 42 LB.
INJECTOR SIZE FOR 650 RWHP = 550+ 100 SHOT ??
INJECTOR SIZE FOR 750 RWHP = 550+ 200 SHOT..??
YOU GET THE IDEA, AT WHAT POINT ARE MY 42 LBS MAXED?
KEEP IN MIND I AM USING A DEDICATED FUEL TANK/PUMP FOR THE NOS..
Is it a wet kit or a dry kit? If it is all to a wet kit with the dedicated fuel sytsem your injectors are not taxed. The 42# will be fine for the motor power. The wet kit will add all the fuel it needs.
Nate
Nate
