View Poll Results: What do you think it will put down!
700-725rwhp
8
27.59%
725-750rwhp
12
41.38%
750-775rwhp
5
17.24%
775-800+rwhp
4
13.79%
Voters: 29. You may not vote on this poll
FI 383 Stroker on the way!
LS1 shortblock with forged eagle crank,forged h-beam eagle rods,-20cc forged diamond pistons,with ARP bolts and a few other goodies!
On the top were going with Lingenfelter satge 2 LS6 heads with comp cams dual springs or patriot gold duals. Custom FI cam,ls6 intake manifold,PP TB, ls6 oil pump,double roller timing chain,60pound motron inj,ligenfelter highflow feul pump,and a Kenne Bell boost pump.
The T-56 has already been built to handle the power and the output shafts have been upgrded to Lingefelter shafts!
The car putdown 600rwhp and 497rwtq on a stock bottom end with ECS Procharged D1SC @ 6psi.
What do you think it will putdown @14 psi and more cubic inches!
other mods are longtube headers,x-pipe,corsa catback!
Originally Posted by Wnts2Go10O
so because u have almost 40 cubes more, its safe to say that it will be at the least, 715.
I hope your conclusion is correct!
It really seems like the larger cube ls1's love boost! That 346ci we did with the procharger D1sc @ 17psi made 714rwhp, we just did a 402ci with a d1sc @ 16psi and it made 757rwhp!
Any questions, just ask!
Originally Posted by C.W.A
what pulley did you use for the 402ci?
They(procharger) told me to run a 4.0 pulley for 12-14 psi! I was making 6-7psi with the 4.75 inch pulley spinning the rpms to 6700! Do you think I have the correct pulley for 12-14psi if I spin it to 6800-7000rpms?
