11 Second Club - think ill make it?
Z28_DAD
09-09-2006, 11:48 PM
mods in sig, plus im going to be borrowing my boss's skinnies if they fit, and my MT ET streets
-PEPE-
09-10-2006, 12:14 AM
What are you running now? For example if you were around the low 12's say around 12.3 you should shave 3 to 4 tenths with those tires and launching right. Do you have the stock 10 bolt? I know some have run 10s on ET streets or drags and been ok for awhile but have seen others toast the axle low 12s & high 11s too.
Z28_DAD
09-10-2006, 01:17 AM
last i ran was a 12.6 @ 110. that was cam ONLY. i was on stock manifolds with a cut out in the i-pipe. i put the car on a small diet too. i dont know what the weight is now, but i took off about 100-200 pounds. i did have the DRs on before too.
-PEPE-
09-10-2006, 01:37 AM
It will be close, maybe 12.1 or 12.2, figure 1/10th for every 100 lbs
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
