F1 Procharger
Old 09-10-2006, 12:39 PM
Restricted User
NBM2001z28's Avatar
Default F1 Procharger
Anyone have a big blower on their car? Post up some pictures, I need some ideas We're shooting for a 408 with a F1...
Old 09-10-2006, 04:31 PM
Frost's Avatar
It fits where the p1/d1 do, you just have to move the bottom of the radiator forward a bit more.
Old 09-10-2006, 05:51 PM
Got Me SOM's Avatar
there is a member here named djs99ss that has done a 408 with a F1 you may want to try to get a hold of him, I think they made it fit by moving the lower radiator up a little bit and the only problem being able to stick the right air filter on there.
Old 09-11-2006, 03:37 PM
Forced370GTO's Avatar
403 with an F1R here, fits right where the d1 sat... this is on an 04 GTO. ill post pics tonight
Old 09-11-2006, 04:01 PM
Turbo LS1 SS's Avatar
the F1 is the same size as the D1.....but if u really want to make some power, step up to the F1C or F1R. these are bigger units, but can still be fit on an fbody. youll have to move u rad forward a little bit, and you wont be able to use the D1's intake elbow. many just use some steel mesh screen. from personal experienve, an F1C ona built 346 is a crazy, violent ride.
Old 09-11-2006, 04:13 PM
DJ's Z's Avatar
Yep, that be me...PITA trying to find a good non-restrictive filter set up. Acutally still working on that. Hope this helps...
TOP VIEW
TILT YOUR HEAD...
DO NOT DO THIS...WILL COLLAPSE ON ITSELF UNDER BOOST! DON'T ASK ME HOW I KNOW
I DON'T RECOMMEND THIS EXCEPT MAYBE FOR TRACK DAYS...
Old 09-11-2006, 04:25 PM
koji777's Avatar
I'm running a 4" aluminum 90. $25 at PepBoys. Had to notch the rad support and tilt her forward, also had to raise the condenser 1" by extending the tabs. Looks great ... zero restriction... running a 4" aircleaner as well... twice the size of the stock ATI in lenth, and of course 4 "
Old 09-12-2006, 09:16 AM
Restricted User
NBM2001z28's Avatar
It'll be an F1R sorry, i didnt post that. We're dealing with a race car so it doesnt have a/c or anything else so i think we should be ok after the radiator support mods. Thanks for the pictures as well...
Old 09-12-2006, 10:03 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Wow that flexible hose stuff would never hold up.
Is that blower a 4" inlet? Have you tried KN RU 2510 for street driving? It's a short stubby filter.
Old 09-12-2006, 12:34 PM
TransAm6383's Avatar
Yeah I was thinking the same thing PSJ..looks like it would suck the whole intake in first time it came into boost..
Old 09-12-2006, 03:03 PM
LS1Tech Sponsor
Slowhawk's Avatar
If it's a race car I would put it where the ABS use to be.Or use a smaller radiator so the inlet can go straight to the front.
Old 09-13-2006, 09:54 AM
LS1Tech Co-Founder
What is the inlet size of an F1R, 4.00 inches? DJ's idea is good for the track but you're probably looking at a custom piece of pipe to mount a filter.
Quick Reply: F1 Procharger
