General Maintenance & Repairs - Cross threaded wheel stud. Help!
sdiddy
09-10-2006, 02:52 PM
Somehow my wheel lock cross threaded and when I try to take it off it just seems to be getting tighter and it feels as though it's going to snap off the wheel stud. Any ideas on how to remove it or should I just order a new wheel stud in anticipation? Thanks.
Revelation Z28
09-10-2006, 02:54 PM
try and get it off without snapping the stud, and re thread the stud.
rollinna65
09-10-2006, 03:03 PM
If its cross threaded like that I doubt you're going to be able to salvage it. I would just keep at it until it comes off, no matter how that may be. Then go get a new wheel stud and lock, they're not hard at all to replace. I swear to god wheel studs are my car's favorite snack. Every time I get new tires the guy likes to try and weld my wheels on with the air gun.
Mr Incredible
09-10-2006, 03:31 PM
Wheel studs are cheap and easy to change. Put some muscle on it utill it comes off or breaks and replace it. You should be able to get a new one at a parts store without having to order it. Might want to take it with you when you go to be sure it looks the same.
Nemo02Z
09-10-2006, 10:47 PM
:werd:
Im gonna piggyback this comment, but a dremel tool would make it alot easier if you can get it in there...
sdiddy
09-11-2006, 12:02 AM
Tomorrow I am going to do whatever it takes to get the dumb lock off. There is no way to get a dremel in there, but thanks.
Brandon35thSS
09-11-2006, 12:31 AM
take a socket thats just a bit smaller than the lock (one you dont mind losing) and drive it on with a hammer,then use a breaker bar to break it loose or it breaks the wheel stud. this wont be a problem at all. wheel studs are cake to replace. ive had to do this to several of my friends cars.
sdiddy
09-11-2006, 09:52 AM
Thanks for the advice. When I get home form work I will give it a try.
sdiddy
09-11-2006, 09:56 AM
Where can I get the new wheel stud from? Summit, Jegs, or can I get it from an Autozone? It's a Moser rear/axle etc., but I think the replacement stud would be the same as stock, right? They are not extended.
Brandon35thSS
09-11-2006, 11:01 AM
i have always got them from autozone.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
