Left over parts
Old 09-11-2006, 09:21 AM
brybe's Avatar
Default Left over parts
I started my transmission assembley last night. I was done with all clutch packs and decided to dissasemble the pump and clean it. After putting everything in the pump back together I was cleaning out my parts washer can and found a 1/4 inch round by 3/8 long spring. Does anyone know if there is a spring this size in the pump. Only other thing I know of would be one of the piston return springs already checked the 3 clutch helper springs and the rev input springs.
Old 09-11-2006, 04:16 PM
LS1Tech Sponsor
performabuilt's Avatar
The spring you are speaking of is probably red or orange in color and it goes under the slide pin in the pump .
Performabuilt
Old 09-11-2006, 07:02 PM
brybe's Avatar
That is exactly where it goes. Thanks so much!
