Flywheel bolts??
Old 09-11-2006, 10:51 AM
1998z28ss's Avatar
Default Flywheel bolts??
Flywheel bolts where can I get them without ordering? Its the last piece I need to install my clutch (and I guess 2 transmission-bellhousing bolts but those can be had at lowes) A friend told me that flywheel bolts are a 1 time use item. He said they stretch and thats how they lock. After you remove them you cannot reuse them.
Any input? Autozone had them in their computer but it was like a 4 day wait
Old 09-11-2006, 12:55 PM
DONAIMIAN's Avatar
I would really try to get my hands on a set of ARP bolts for safteys sake. Thoes are some bolts that you dont want to let go in the upper RPM's.
Old 09-11-2006, 01:29 PM
1998z28ss's Avatar
Yeah but looking for something I can get my hands on quick. Thats the last thing I need (other than figuring out some way to jimmy this quick release on my slave) to install my clutch and get my car on the road.
Old 09-11-2006, 01:43 PM
Ramshaft's Avatar
they might be more expensive but the dealer usually has stuff like that on hand. I did not know you were supposed to replace the bolt. When i did my cluch install I used the same bolts that were on there before. I have not had any problems and I hope I don't in the future. Good luck
Old 09-11-2006, 03:59 PM
1998z28ss's Avatar
Well I would reuse them but a good friend of mine that has been building motors and stuff for years says that they stretch once you put them in and therefore become a liability if you reuse them.
Old 09-11-2006, 04:08 PM
Ramshaft's Avatar
never heard of that, hope mine last till the next time I change my clutch.
Old 09-11-2006, 06:51 PM
gd1996's Avatar
They are hardened bolts... resuse them or get arp.
Old 09-11-2006, 06:57 PM
1998z28ss's Avatar
yeah some of the heads on mine were a little messed up. I managed to find them at a dealer only like 10 miles away for 1.25 a piece. Not to bad. Now when you guys torqued them down did you use a screwdriver to hold the flywheel or actually got a tool? A screwdriver worked great for removing them...
Old 09-11-2006, 09:29 PM
Ramshaft's Avatar
I had my buddy hold it with a pry bar and that worked great.
Old 09-11-2006, 09:43 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I got a flywheel holding tool from Jegs, which is also where I got my ARP flywheel bolts - one call gets it all, one click gets it quick!
