Gaskets w/ LS6 Coolant Tubes?
Old 09-11-2006, 05:54 PM
Ferocity02's Avatar
Default Gaskets w/ LS6 Coolant Tubes?
Well I noticed that the LS6 coolant tubes, the ones that cross over from one head to the other, have o-rings on them, while the stock LS1 coolant tubes dont. So are you guys still using the coolant gaskets/seals(12551933)? I'd imagine not, but I'd like to see what others are doing. I am planning on running two front LS6 coolant tubes in case you were wondering.
Old 09-11-2006, 06:17 PM
joshp14's Avatar
They switched to a new design. The old design was just the tube with flat gaskets....the new style has rubber o-rings that come with the tube.
Old 09-11-2006, 06:26 PM
ROCNDAV's Avatar
Is it just me, or do the LS6 caps (rear) look crooked because of the oring when they are installed?
Old 09-12-2006, 11:08 AM
ShevrolayZ28's Avatar
I don't know. But don't forget to block off the holes in the back of the heads. And do it before you install the heads!
Old 09-12-2006, 11:27 AM
LS1TECH Sponsor
badpewter-z's Avatar
yup redesigned about 6-8 months ago . all the new tubes and block offs use orings now .
Old 09-12-2006, 11:47 AM
Ferocity02's Avatar
I'm using two front coolant tubes, one in the front and one in the back to help keep the back cylinders cool also. The motor is out of the car so installing these is no feat.
Quick Reply: Gaskets w/ LS6 Coolant Tubes?
