m6 trany oil
Old 09-12-2006, 01:14 PM
white mongoose's Avatar
Default m6 trany oil
i just replace my drive shaft on my 98 m6 and like 1/2 a quart off trany oil leak just wondering through were u put the oil in it thanxs
Old 09-12-2006, 01:20 PM
Mad-Max's Avatar
On the drive side of the trans. there is a fill plug. Use a 3/8' ratchet to remove this plug and add your trans fluid until it starts coming out of the fill hole. It is easier to add the fluid if you have a pump( you can get this at any parts store).
Old 09-12-2006, 04:09 PM
thanxs alot man cause since then my clutch was filling kind of wierd thanxs ones again
