Grounding connections
Old 09-12-2006, 04:12 PM
Stroker2112's Avatar
Default Grounding connections
Guys,
Does anyone have a link, documentation, and/or diagrams referencing where all the grounding connections go on an LS1 engine?
This is the only thing holding me up on my 408 rebuild...can't wait to start it up.....
Stroker2112
iron 408ci, forged, TorquerV2, Patriot CNC'd 243 heads, Patriot Golds, true dual exhaust w/flowmasters, K&N Air, and every other free mod known to mankind
Old 09-12-2006, 10:17 PM
ShevrolayZ28's Avatar
I know mine has three ground wires bolted to the back of the DS head.
Old 09-12-2006, 10:19 PM
Ferocity02's Avatar
Yes, three on the driverside head, I think one on the driver's side block, behind the alternator. Probably one or two more I'm missing.
Old 09-12-2006, 10:20 PM
ArcticZ28's Avatar
A ground is a ground is a ground. Find something metal and ground the wires that need to be grounded. The back of the head is a good place for the wires that need to be grounded back there. You can also use the engine as a grounding point or find some bolts on the car nearby.
Old 09-13-2006, 03:42 PM
THanks.....I'll make sure they get on either a head, block, or the frame.....
Stroker2112
Old 09-13-2006, 05:18 PM
pewter 01 SS's Avatar
Theres One Ground That Goes In The Passengers Side Head, Two In The Drivers Side, One On The Drivers Side Of The Block Near The Motor Mount And One That Your Going To Have To Decided Where To Put To The 6.0 Block Near The Started Since The Hole That 5.7l Had For The Ground Is Not In The Same Place For A 6.0l Block
