Which injectors do you recommend?
I'm in need of injectors. I'm cam'd and have a lot of bolt on's. No heads yet. No NOS either. I was looking at the TSP 42# injectors. They seem like a decent price. Anyone have some recommendations?
We carry the Racetronix fuel injectors:
http://www.harrisspeedworks.com/shop/home.php?cat=331
Instock & ship the same day.
Matt
Matt
Originally Posted by 2002SilverWS-6
30's should be able to handle 500rwhp but if you power add then 42's will work.
(500hp X .5)/(8*.8)= 39.5 lbs/hr.
Assuming a 45% BSFC (500hp x .45)/(8*.8) = 35.1
Not sure what a H/C LS1 qualifies as for BSFC, but you can see that in some cases a 30# SVO (36lb) won't be enough. Also, you can get flow matched 42's on fleabay for $280 shipped (I just ordered a set) so they're just as cheap or cheaper than 30's!!!
Originally Posted by Billdog350
If you use one of the many online calculators...50% BSFC
Restricted User
Originally Posted by RedHardSupra
you mean you can't find these?
http://cgi.ebay.com/ebaymotors/8-Bos...QQcmdZViewItem
If I buy these, would you be able to provide all of the required tuning tables that correspond well? Will they work well with the stock tables + the cahnge to the flow rate table as per your calculator? I know that my troubles are not the cam as this is the second cam with the same problem. The rest of my tune is pretty close to perfect. I have spent hours trying to dial it in the stated problem areas. I have gotten it to where it feels like a vibration but I want it puuuuurfect. I think that the problem must be in the injectors min pulse. I hear that these Motrons wont go below 1.5 and I have never seen mine drop below 1.7. I have zeroed out the adder table and have the min set to .5 and nothing. I have tried many settings inbetween also.
I have made changes to all of the air flow tables as well.
