O2 Sensors
Old 09-13-2006, 12:10 AM
01blackbeast's Avatar
Default O2 Sensors
I don't know if this is the right forum to post this in or not, so please let me know if it isn't. Anyway, can you use a rear O2 sensor in the place of a front one that went bad? Thanks.
Old 09-13-2006, 12:37 AM
RrCoX22's Avatar
first off no you can't that's why they are specifically called front and rear O2's
second you CAN use the vette's rear O2's for the front if that's where your getting that concept
third... you should know what's coming... up top read and learn
Old 09-13-2006, 01:05 AM
Shallow Bay's Avatar
Fourth, you should know that the only difference between the front and rear O2 sensors is the length of wire they each have. Other the length of the wire harness, they are all the same.
Old 09-13-2006, 01:21 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
And you say I am in an interesting mood.
Here you go man: https://ls1tech.com/forums/generation-iii-external-engine/500407-egr-air-o2-sensors-motor-tranny-mount-faq.html
