sd-concepts ?'s
sd-concepts ?'s
I just placed an order for the sd-concepts 8 rib pulley system with the 3.75 inch pulley(rated at 7-9 psi) to replace my 5psi 6 rib system on a p1sc procharger. my question is, will i be able to get by with the 38# injectors ati sent with my system? im kind of running low on money and would like to not spend too much more on this system right now. my car is an 02 camaro all stock cept for the intake is an aluminum weiand. i do have hp tuners and my boss is pretty good with the tuning portion as he has tuned the 5psi system thus far with no probs and good results. if anyone knows of any other problems i might run into that would be appreciated too.
thanks
thanks
As long as you have a booster pump or an aftermarket intank pump, you should be fine. if you do not have either, I wouldn't go into boost until you do. Just my $.02
