What am i missing in my engine bay?
Old 09-13-2006, 03:19 PM
Bad Blue WS6's Avatar
Default What am i missing in my engine bay?
When facing the cars front end, hood open, i have two screw holes on top of the passenger side wheel hump....what am i missing there? Its on the very edge, near the fender. I have seen pics and something is there, but my car does not have it...(2nd owner)
Also
i have one cable on my TB but there is a "nub" and an empty slot in the cable bracket,,,i have both traction control and cruise control, and both work fine as far as i can tell,,,,what goes on this "nub"? Thanx everyone
Old 09-13-2006, 03:40 PM
NVR_SPDS's Avatar
Can you post a pic?
Old 09-13-2006, 03:53 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
Originally Posted by NVR_SPDS
Can you post a pic?
yeah........
Old 09-13-2006, 03:55 PM
ArcticZ28's Avatar
Are you sure you have traction control? You have a TCS button up by the foglight button? From what you explained, the things missing sound like parts of the TCS.
Old 09-13-2006, 04:47 PM
LS69TA's Avatar
I believe you're talking about the TCS module thingy. It goes behind the battery and fits in the recessed area on the fender.If you need one, PM me.
Old 09-13-2006, 05:47 PM
Grimes's Avatar
traction control spot...i don't have the box, but have the holes you speak of, lol
Old 09-13-2006, 05:54 PM
SweeTbone's Avatar
You have a Trans Am, so your Traction Control System switch should be right in front of the shifter next to cigar lighter. Traction Control is NOT the "Low Trac" light that comes on when you downshifting and lose traction or when your brakes lock up. Do you have this switch or no?
Old 09-13-2006, 05:59 PM
FBodyPerformer's Avatar
you should only have 1 cable running to the TB if you have TCS and cruise.
And are you talking about the bolts that hold your strut and springs in ontop of the wheel well in the engine bay?
Old 09-14-2006, 08:26 AM
Good morning everyoiine, thanx for all the help. Im an idiot with the pic thing so i cant do that,,,(i tried as u can seee in my sig, but nada) but i do have a switch next to my lighter, really dont know if it does anything, cause i hit it, and nothing really happens, (lights, etc) Sometimes, usually during wheel hop, my TCS light will show on the dash, so i always thought that i did have it. Some of you mentioned that the recessed area of my fender hump is where it would be, and this is exactlly where i show nothing but 2 holes. Someone up here also said to pm them,,i will right after this post
Old 09-14-2006, 08:57 AM
warp10's Avatar
If you have TCS, you will see this unit on the picture which would be to the left of the A/C condensor.
Old 09-14-2006, 08:59 AM
LS69TA's Avatar
Yea, that's the piece I have. Bad Blue WS6 I'll get those pics to you if you still need them. Just let me know.
Old 09-14-2006, 09:19 AM
thanx to you all....yep,,that lil box thing that is to the left of the firehawk logo on the wheel hump in the big pic above is where i have the two holes, and no box. I do have th eswitch, and on my original widow sticker, it states that i do have it. I am the second owner (originaly the Nasty Performance track car),,Nate must have removed the box,,does anybody know why someone would want to remove it? My car was modded much more than when i bought it ( things were removed and put back to stock, or as close to it as possible, i.e. corvette cam, etc.)
Old 09-14-2006, 09:20 AM
warp 10 - i have that same rub spot on my lid.
Old 09-14-2006, 09:44 AM
warp10's Avatar
Yep. I have a WS6 lower box which has a bigger opening. That is why it's rubbing.
If you have a different rear end, they might have removed the TCS.
Old 09-14-2006, 10:18 AM
JerseyLS1TA's Avatar
here's you sig pic, just save it and re-size it.
Old 09-14-2006, 10:44 AM
SweeTbone's Avatar
Here it is resized to a sig pic. Right click, save it, then upload it to your Photobucket account. Use the 3rd line of text under the pic in your photobucket accout with the brackets in your sig.
Code:
[img]your photobucket pic url[/img]
Old 09-14-2006, 01:55 PM
2xLS1's Avatar
If you only have 1 cable on your T/B and do not have the ASR/TCS servo motor behind the battery, there is no way your cruise control or traction control could work.
Old 09-14-2006, 03:53 PM
Cruise control works perfectly,,i use it all the time.
Old 09-14-2006, 03:58 PM
Thanx for the help with the pics!!!!!
Old 09-14-2006, 04:03 PM
DanZ28's Avatar
Then I'm lost as to what's missing. If the part that all the cables go into is missing, TCS and cruise will not work. Does the cable on the throttle body go straight into the firewall then to your gas pedal? Do you have air conditioning? is that whats missing?
Dan
