Clearance needed to get oil pan off? Will this work?
Old 09-13-2006, 09:56 PM
csmc711's Avatar
Default Clearance needed to get oil pan off? Will this work?
If i took off my LS1 heads off my camaro and jacked up the motor by the trans, would that give me enough clearance to drop the oil pan?
Old 09-13-2006, 10:03 PM
SS4Matt's Avatar
on an F-Body? i'm gonna have to guess no. i dropped a lifter down my motor on accident a few weeks ago when i did another cam swap...and i couldn't get my pan all the way out. even with getting the pan undone, and dropping the oil pump and pickup, i still couldn't get mine out. i just had to slide the pan to the left and to the right to get my hands up and in to get the bastard lifters out. (dropped the windage tray there too) anyways, this is what i was working with ....
Old 09-13-2006, 10:18 PM
jermzz's Avatar
youre also gonna have to drop the k member down as far as it will go. Problem is the pick up tube sits in the bottom of the pan in a hole barely big enough for it, so you have to drop it far enough to clear that, then you can angle it out.
PS i hope you took your heads off for another reason then just changing your oil pan. cause if not you did it the hard way!!
Old 09-14-2006, 08:37 AM
csmc711's Avatar
I had to take the vave covers off because they were leaking. When I got in there, the rockers, valve spring and pushrod was rusted up a little bit, right under where the hood seal lip is. Since everything on this car is fawked up, I am thinking, while I have the covers off, to take the heads off and put them back on to make sure they were installed properly as I have a 9/97 camaro and the heads are 241 castings from another year. Well, I figure, if I have the heads off a 100k engine, might as well replace the rings also, right? Hmmm, but I need to drop the oil pan too, so...........
Old 09-24-2006, 12:40 AM
csmc711's Avatar
Damn, that toatly blows, oh well, I found slight rusting of the 1 and 3 cylinders, so, I guess all that ring work would not matter anyways.
Thanks.
