Help, My ws6 burns oil. Y?
I have 01 ws6 and it burns oil and smokes when I get on it.The smoke color is like a blueish and it only has 54k miles. Im getting a cam (Torquer v2) but I don't wana hurt my motor if there is something wrong with it already. I was woundering if anyone can help me out and tell me whats wrong with my car and if its safe to go ahead and put the cam in it. Any help would be good , Thanks.
that 160* thermostat could be the possible guilty party. Its not allowing te engine to reach proper operating temps. Thus allowing oil to slip. I had a 185 and dynoed 13 hp less with it vs the factory, plus ran rich and smoked like a train. A friend has a 408 that runs in the 9's with a 160 and it was losing 22rwhp over stock.
Originally Posted by zapp168
Could you explain, "oil to slip?" Thanks
If you are blowing blue smoke on acceleration you're rings are probably worn, you can try checking A/F ratio and blocking off the PCV to make sure but more often than not it's rings.
If you are smoking on deceleration it's usually guides, PCV, or rocker bolts.
