93camaro_zzz
09-14-2006, 03:18 PM
Hey guys,
I just got my LS7 clutch done, and everything went fine (8hours of work), and then I bled the clutch and after I did the first start, the clutch engages about a 1/2" off the floor. Before with just stock clutch it would engageat the top of the clutch pedal (ideal). So I went back and bled it alot more. It had some dirty fluid, so I bled it ALOt both times to get that all out of there. Well after the second time of thoroughly bleeding it, it engages about an 1" off the floor. Only slightly better. When I did the clutch, I did replace the slave with an 02 slave cylinder brand new. So I new that would be dry new, so thats why I bled it alot, and its still not right. I am breaking it in all this week and hitting the track this weekend. Obviously it will drive right now, but its not perfect. Does anyone have any ideas, or know something I might have missed? I cant think of anything. I mean I am pretty sure I am bleeding it correctly. My method was as follows:
1. Have friend pump clutch 3-4 times and then have the clutch pushed to the floor.
2. I open bleeder valve for about 3-5 seconds and then close it.
3. My friend brings clutch pedal up to original postion.
4. Repeat about 12 times.
Just wondering if anyone has any advice. I ould much appreciate it. Thanks guys, ;)
