Cam Question
Cam Question
Just wanted to get some input on this cam. 224/228 with a 581/588 on a 114 lca. Is this a good cam for a car that is just driven on the weekends and taken to the track as often as work allows. I will be combining this with Jet Hot long tube headers and ory. Wanting to stick with the stock stall for now until i can afford to get the tranny built. Already have 3.73 rear gears with an auburn posi. Just want a little lope and some extra power!
Yea thats a good cam for what you want, though you might want to consider upping the stall. That stock one wont last to long imo. By the way who do you plan on having install the cam and who is doing the tune?
Cool man he'll hook you up, Also Id send him a PM before I did anything just for advice at the least he was gonna install my cam and valvetrain for me but now im getting rid of the car.
I have a close cam, you can check my sig. I run 12.6 @ 114 on street tires, and I will admit I cannot launch to save my life. 2.2 60' times average either spinning through 2nd or bogging. Idles smooth, with enough lope to know it is not stock. lot of valve noise though, not sure if it was the heads or the cam causing that
Want bigger than 224 try the 228-mid 230's.The 224/228 is good but I would do the TC first something like 3500-4000 you said the cars not a DD and goes to the track alot. Bigger stall 1st..Cam 2nd!!
