what Lifters for a high lift head/cam swap?
Old 09-14-2006, 06:33 PM
Asmodeus's Avatar
Default what Lifters for a high lift head/cam swap?
morel?
rhoads?
eaton?
comp r?
ls7?
fresh stockers?
other?
Old 09-14-2006, 07:15 PM
Cop Car's Avatar
LS7 lifters. GM parts direct $125 to your door.
(fyi its the same as LS1 lifters, it just apparently had a small revision for "LS7 high rpms" whatever that means)
Old 09-14-2006, 07:18 PM
Cstraub's Avatar
Morels are rated for .695" lift. The OEM's in the low .600ish range.
Chris
Old 09-14-2006, 07:49 PM
speedyss's Avatar
is there a hyd roller lifter out there that can hold up to, say 600 pounds of open spring pressure and good to like a .650 lift or more would be even better, but i guess thats asking a lot for a hyd roller, lol.
Old 09-14-2006, 10:11 PM
Asmodeus's Avatar
yeah I'd like to know that too
can I just throw some solid lifters in? lol
Old 09-15-2006, 10:48 AM
SLED28's Avatar
Uh Yah!!
To the original poster, go MORELS all the way! best lifter around, takes a beating, makes power and goes .700lift!!
Old 09-15-2006, 01:00 PM
Cstraub's Avatar
I have customers running as much as 190# seat pressure and 550# Open pressure on the morels in heavy BBC valve train combos for marine application. This is at sustained rpms of 5K for 20 minutes.
Old 09-15-2006, 01:25 PM
SLED28's Avatar
Just another reason to go morels! I think this lifter is one of the best auto performance designs in a long time
