Modifying ls6 engine for road racing. Flat powercurve
I built a tube frame car for road racing. I want like another 100 horsepower for next year. As you can see it already has a kinsler intake and long tube headers. I think i want to spend like 2 grand. I could do heads and cam for that, but i do not think i really need to touch the heads with the stock flow numbers 500 hp should not be hard to acchieve.
[IMG][/IMG]
[IMG][/IMG]
Please explain why i want a low lsa like that and why so much overlap.
This is a link to more pictures.
https://ls1tech.com/forums/conversions-swaps/569385-pictures-completed-autocross-race-street-car.html
Go to this link for a thread on the car
https://ls1tech.com/forums/showthread.php?t=569385
Supercharging it crossed my mind. That would give more usable power down low but how good are the centrigical style
!LS1 11 Second Club
Try a 228ish thru 230 duration cam on a 110 lsa with about .57x lift, Comp XE grind for spring longevity. Though, given your fancy shmancy intake, seriously consult someone who can help you match a cam to your setup. Give Katech a call.
I would not consider supercharging if you plan to track the car. It adds more compexity to the set up and if you throw a belt while driving around the track you can hurt the engine in a hurry. I have seen an ati equiped firebird go home on a flatbed because of this. Not to say it can be done just more things to go wrong. I think given the weigth of the car you should be fine with a nice cam. Maybe some shaved AFR 205's. But you are probably going to have to go custom in order to take advanage of your intake and free flowing exhaust. Try Ed Curtis
BTW, Maybe I'll run into you next year at Waterford Hills (I was there early this year and was a blast. Unfortunately I will not be able to go back until next year.)
!LS1 11 Second Club
Originally Posted by Killer_Bluebird
I would not consider supercharging if you plan to track the car. It adds more compexity to the set up and if you throw a belt while driving around the track you can hurt the engine in a hurry. I have seen an ati equiped firebird go home on a flatbed because of this. Not to say it can be done just more things to go wrong. I think given the weigth of the car you should be fine with a nice cam. Maybe some shaved AFR 205's. But you are probably going to have to go custom in order to take advanage of your intake and free flowing exhaust. Try Ed CurtisBTW, Maybe I'll run into you next year at Waterford Hills (I was there early this year and was a blast. Unfortunately I will not be able to go back until next year.)
!LS1 11 Second Club
Originally Posted by silver01z06
without doing heads to get the power you are talking about you will need a pretty big cams. big cams normally have a peakier power curve.
