Sponsored by: DashLynx
Shift light locations
Old 09-15-2006, 12:09 AM
99camarosupersport's Avatar
Default Shift light locations
Just picked up a shiftlight and i'm wanting to get some ideas on placement, i'm thinking a pillar or on the dash to the right of the steering wheel, toss me some ideas lil buddies.
Old 09-15-2006, 12:36 AM
Import Patrol
CrawlinWS6's Avatar
The little vent on the pillar is the best place IMO. If you get the correct size light that is.
Old 09-15-2006, 01:00 AM
RoastEmSS's Avatar
Old 09-15-2006, 01:09 AM
blown 346's Avatar
Originally Posted by BLACKNREDSS
I was just going to say in the right vent.
Old 09-15-2006, 02:41 AM
Are those the raptors?
Old 09-15-2006, 08:04 AM
mrbobo's Avatar
I put my Raptor inside my TA's center AC vent. Very stealth, and I see it just fine. I had to fabricate a small base, so that thelight was angles correctly, no big deal tho.
Old 09-15-2006, 08:20 AM
nokeman's Avatar
The vent is a good place, but I kinda like the little hole on the a-pilliar. Its almost like it was meant to go there haha.
Old 09-15-2006, 09:10 AM
RoastEmSS's Avatar
Harlan
Old 09-15-2006, 09:18 AM
dirtybird22's Avatar
Thats super sneaky
Old 09-15-2006, 09:55 AM
99_Z_155's Avatar
Mine is in the same spot as blacknred's, except blue Works like a charm, and nobody sees that ****.... Its also a harlan. i just velcro'ed it to the floor of the vent. job complete......
Old 09-15-2006, 02:34 PM
71camaro's Avatar
I have a blue Raptor that I put in a couple of nights ago. I put it in the defrost vent on the pillar. I like it and its hidden.
Old 09-15-2006, 02:45 PM
Harlan
ok that's what im getting, idk why in the hell i said raptors
Old 09-15-2006, 02:46 PM
Dal1as's Avatar
Look above the odometer. Eventually I'm going to get a new bezel and do a cleaner install.
http://www.carstereo.com/installs/ph...w=1&maxrows=12
Old 09-15-2006, 03:47 PM
Ace$nyper's Avatar
Harlen in the vent like pictured. Works like a charm
Old 09-15-2006, 07:28 PM
_JB_'s Avatar
I have mine in the dash vent, driver's side.
Old 09-15-2006, 08:34 PM
frisky2101's Avatar
was goint to put mine (raptor) in the pillar vent but wanted to be able to put the cover on and off easily. Put mine right in front of the shifter in the little pocket you don't even notice it until you look for it
Old 09-15-2006, 08:41 PM
99blancoSS's Avatar
Put it where you can easily see it while your staring down the track. It wont do any good if you have to look for it. It should be where when it lights you see it while your staring straight ahead. I've got a mini light mounted to my tac on the steering column.
Old 09-15-2006, 09:31 PM
Jon B.'s Avatar
I put mine on the column as well, it is a Raptor and it's held in place by a little bit of velcro. Everyone asks if it came stock so it doesn't look out of the ordinary at all if you ask me. I didn't think Harlan was still making his shift lights?
Jon
Old 09-17-2006, 12:51 PM
98mysticZ's Avatar
mine is at the corner of the dash/apillar on the drivers side its hidden under my registration sticker
Old 09-17-2006, 09:43 PM
z28chic's Avatar
i have mine on the drivers side....on the pillar where the defrost vent is at
Quick Reply: Shift light locations
